wolay
Feb 22, 2015Follower
RN102 - can't connect to web-interface after uninstalling app
Hi, I’m new user here because I have problem whit my ReadyNas 102 Can't connect to the web-interface (web admin panel). Installed and uninstalled the ReadyNAS Photos II app. Already tried to ...
- May 17, 2016
OK So I have fixed my issue without having to go to the linux level
If you have set up a readycloud account, you can log in there and upgrade your firmware remotely.
This worked for me, I hadn't thought of this until Netgear informed me that my readycloud account was going to close and once I got in I upgraded the firmware and now I can access the admin page through the network
rayza
May 17, 2016Aspirant
- mdgm-ntgrMay 18, 2016NETGEAR Employee Retired
Yes, there are other options (which are more involved) too such as:
1. Power down ReadyNAS
2. Remove disks (label order)
3. Insert scratch disk (must not be from the array)
4. Update firmware
5. Verify firmware update successful
6. Power down
7. Remove scratch disk
8. Put disks back in same order as before and power on
