wolay
Feb 22, 2015Follower
RN102 - can't connect to web-interface after uninstalling app
Hi, I’m new user here because I have problem whit my ReadyNas 102 Can't connect to the web-interface (web admin panel). Installed and uninstalled the ReadyNAS Photos II app. Already tried to ...
- May 17, 2016
OK So I have fixed my issue without having to go to the linux level
If you have set up a readycloud account, you can log in there and upgrade your firmware remotely.
This worked for me, I hadn't thought of this until Netgear informed me that my readycloud account was going to close and once I got in I upgraded the firmware and now I can access the admin page through the network
mdgm-ntgr
Mar 02, 2015NETGEAR Employee Retired
Hi Tomasz555 , I sent you a PM.
M69S
Sep 10, 2015Aspirant
Hi
I am in the same case.
ReadyNas works fine to access the file but impossible to access the admin interface.
Too bad you send the trick to restore it in PM :)
Thanks for your help,
Mickael
- StephenBSep 10, 2015Guru - Experienced User
M69S wrote:
Hi
Mickael
Do you have ssh access? What firmware are you running?
- M69SSep 10, 2015Aspirant
Nope SSH does not seem to be enabled and I don't know the exact firmware number (something like 6.x)
I am currently backuping the data (only 15h left 😃) before doing a factory reset.
I just hope that it won't happen again ! And next time I will enable ssh.
