volfra
Dec 31, 2014Aspirant
RN102 - No upgrade to 6.2.2 (looping) - SOLVED
Hi, in august 2014 I bought 2 identical ReadyNAS 102 diskless systems. The first is supplied with 2x320Gb WD HDD, the second with 2x3Tb WD HDD. The operational status of both the units is OK (I can a...
volfra
Jan 04, 2015Aspirant
Hi, solved after performed a "Factory default" hard-reset to the unit. Now the unit is updated to 6.2.2.
