Eaglehawk
Jun 17, 2017Apprentice
GSS108E firmware 1.0.0.10 upgrade loop
Well, after a few successful upgrades since the ARP debacle, I thought the upgrade to the 1.0.0.10 version would be a no brainer.
Upgraded to the new ProSAFE Plus Utility 2.4.3, selected the GSS108E, pointed to the new 1.0.0.10 firmware, said it was succesful. Went to the IP address with the web browser to do the bootloader part...and it was still asking for the firmware file...
Tried that, restarted, same result...it's not progressing to the next stage after a restart.
Am I missing something?
Swap unit arrived. It still had the 1.0.0.0 firmware. Followed the steps as per the 1.0.0.10 instructions for this firmware revision (as I still remember the TFTP problem).
Still had the same problem (The TFTP one, not the firmware loop). So I had to put manual arp entries in for the new switch to make it take the firmware upgrade. I thought this was fixed with the 2.4.3 version of ProSafe? Did I miss a step?
Anyway, all working now. Hope no one else has this issue :)
- XavierLLNETGEAR Employee Retired
Hi EagleHawk,
After you finished your firmware upgrade could you open a web browser with the below address:
http://x.x.x.x/loader_upg.htm (x.x.x.x it's the ip address of the switch)
And update the bootlader?
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
- EaglehawkApprentice
I already tried that.
Asked to upload via TFTP, tried the TFTP2.exe method. Nothing.
(As a side note, the upgrade on my GSS116E worked fine, so I know it wasn't my method or firewalls etc...)
I've also tried to downgrade to an older firmware, and a power off/on. I haven't tried a factory reset yet, because that would involve pulling out the unit from the back of the cabinet...
It appears to rejecting any firmware I upload. The web interface will only let me submit a firmware file, the ProSAFE utility has an * next to the device, and only asks for a firmware upgrade. I've downloaded the firmware file from a different computer/browser to make sure it wasn't corrupted. I've tried 3 different browser types, two different computers, Windows Firewall all disabled.
Anything else?
Hi Eaglehawk
I would suggest also to try to do an upgrade first to the 1.0.0.6 version and later on do the upgrade to 1.0.0.10 if you haven't try it yet.
https://kb.netgear.com/31087/GSS108E-Firmware-Version-1-0-0-6
If this doesn't work I would suggest you to open a chat / online with NETGEAR Support and let them know the status of the GSS108E switch.
Xavier Lleixa
NETGEAR CBU PLM
