volfra
Dec 31, 2014Aspirant
RN102 - No upgrade to 6.2.2 (looping) - SOLVED
Hi, in august 2014 I bought 2 identical ReadyNAS 102 diskless systems. The first is supplied with 2x320Gb WD HDD, the second with 2x3Tb WD HDD. The operational status of both the units is OK (I can a...
mdgm-ntgr
Jan 13, 2015NETGEAR Employee Retired
Vincentoz it looks like the RAM has failed in your unit. The RAM is soldered on so the unit needs to be replaced via RMA.
