Retired_Member
Aug 26, 2017RN102 doesn't read SD card formatted in Nikon D3300
Hi, My RN102 has a problem with reading SD card via USB card reader - it depands on formating method. 1) SD card formatted as FAT32 in Windows 7 - new storade is detected - every thing is OK 2) SD...
JennC
Aug 28, 2017NETGEAR Employee Retired
Hello ckarol86,
It must mean that there is something being added to the disk when inserted to the camera. We don't really normally use card reader on the USB ports of the NAS as those were designed for HDDs' USB.
Have you tested the formatted SD card on Windows 7 if the computer will detect it?
Retired_Member
Aug 28, 2017I spent a bit time on testing various of situations.
Below I will describe what I checked already:
1) I used 3 different card readers: is not card reader compatibility problem
2) SDcard is recognized as sdd1: hardware is OK
Device Boot Start End Sectors Size Id Type /dev/sdd1 8192 61896703 61888512 29.5G c W95 FAT32 (LBA)
3) When I mount it manually: it works, I can read files (in /mnt/sd) but card is not detected in admin page
mount /dev/sdd1 /mnt/sd
It looks like this is automount 'script' doesn't mount it automatically, but why...?
- JennCAug 29, 2017NETGEAR Employee Retired
Hello ckarol86,
Maybe other users who do this might help and share their thoughts, I don't do this to USB ports of ReadyNAS.
