anserk
Nov 05, 2017Aspirant
RN102 mixed drives
I'm trying to use two drives with different sizes (1TB and 5TB) and get some level of protection. According to https://kb.netgear.com/21387/What-is-the-volume-capacity-when-installing-disks-of-differ...
- Nov 06, 2017
That article is accurate for Sparc ReadyNAS, the last of which was discontinued about 6 years ago now.
anserk
Nov 06, 2017Aspirant
I did try both X-RAID and Flex-RAID. It doesn't give ability even to select to drives - nothing happens when I click on the 5TB one (buttons to the right remain unclickable).
I'm starting to suspect that article applies only to 4-drive models, although it's not clear. From Linux perspective it should be possible to partition the larger drive and use that partition along with the smaller drive for RAID, and then use the other partition as a standalone volume. I was hoping ReadyNAS OS would allow something like that.
Sandshark
Nov 06, 2017Sensei
The whole article appears to be false. In XRAID, so long as you start with all 4 drives in their example, or at least include the smallest at the begining, you can use all of the capacity except when there are just two drives. With all four, there would be one 4x250GB layer and one 3x500GB layer, all as one volume. It is in FlexRAID that the smallest drive limits the size.
Maybe this was true for the legacy OSes? I never had a mix of drive sizes in mine.
- mdgm-ntgrNov 06, 2017NETGEAR Employee Retired
- anserkNov 06, 2017Aspirant
Thank you for clarifying. That article certainly should have something about the specifics. Last updated timestamp is only a year ago, making it look even more trustworthy.
- SandsharkNov 07, 2017Sensei
Applicability notes are an ommission in a lot of the KB articles. Perhaps Netgear expects people will go to them only when directed to do so, but that's certainly not true. They show up in web searches and folks expect them to be accurate for all systems when there is no indication otherwise, and even moreso when the date on them is recent.
Assuming the date means the last time the article was reviewed for accuracy, the person doing the review did not do a very good job.
