vkoukoutis
Dec 09, 2015Aspirant
RN102 Network & Port settings
Hello people.Recently i bought an rn102 with 3tb red disk ,. I did install all fine , i am able streaming my movies/series to my smart tv though that happens only in my home. When i am out and wann...
- Dec 10, 2015
You shouldn't be using port 80. The admin panel uses https, not http. That usually uses port 443. Port 80 won't work unless you enable http admin access in the NAS (which you SHOULDN'T).
So you could forward 443.
But If you have other devices that you might want to access remotely (including your router's admin page) you can pick a different port to forward. For example 54321. You'd configure 54321 as the secondary https port in system->services. Forward 54321 in the router. And access the admin page as https://vkoukoutis.ddns.net:54321/admin
vkoukoutis
Hello and thank you
Well , i want to be able to use my files outside home from my iPhone Application & an another computer so i can use my Transimission / Plex and generally my whole Nas functionality.
BrianL2
Dec 09, 2015NETGEAR Employee Retired
Hi vkoukoutis,
Check the following articles.
Using ReadyCLOUD app for iPhone, to access your ReadyNAS files remotely
Using ReadyCLOUD app for Windows, to access your ReadyNAS files remotely
Kind regards,
BrianL
NETGEAR Community Team
- StephenBDec 09, 2015Guru - Experienced User
You will need to forward the plex port in your router to the NAS. That involves reserving an IP address for the NAS in the router, and forwarding the port to the IP address. The default port that Plex uses is 32400 - but you can change that in the plex ui if you wish.
ReadyCloud is a convenient way to access your files remotely, but there are other ways to access your NAS remotely, you can ask about them here if you find ReadyCloud doesn't meet your needs.
