vkoukoutis
Dec 09, 2015Aspirant
RN102 Network & Port settings
Hello people.Recently i bought an rn102 with 3tb red disk ,. I did install all fine , i am able streaming my movies/series to my smart tv though that happens only in my home. When i am out and wann...
- Dec 10, 2015
You shouldn't be using port 80. The admin panel uses https, not http. That usually uses port 443. Port 80 won't work unless you enable http admin access in the NAS (which you SHOULDN'T).
So you could forward 443.
But If you have other devices that you might want to access remotely (including your router's admin page) you can pick a different port to forward. For example 54321. You'd configure 54321 as the secondary https port in system->services. Forward 54321 in the router. And access the admin page as https://vkoukoutis.ddns.net:54321/admin
vkoukoutis
Dec 10, 2015Aspirant
Sorry for double post
About the ports I did it but only think I can access is my Plex not transmission
And if my Nas ip change I also have to change it in my port foward
Dec 10, 2015Guru - Experienced User
If you can access transmission locally in your browser, there almost probably is a way to forward the port. If it has to be 8181, you can still forward port xxxx to port 8181 in the router. If the web app is mis-designed you might have a problem (sometimes controls and images hard-code the port in the html). But that usually isn't the case.
As far as IP address changes - almost all routers have a way to reserve the IP address that is assigned. On newer netgear routers that feature is called "address reservation". The name is sometimes confusing in other routers - if you can't figure that out, post the router model here. A link to the user manual for the router would also be helpful (I'm far more likely to respond if I don't have to scour the internet for the manual).
Of course any forwarding does expose the NAS to the internet, so you want to be selective about what you forwarding.
