vkoukoutis
Dec 09, 2015Aspirant
RN102 Network & Port settings
Hello people.Recently i bought an rn102 with 3tb red disk ,. I did install all fine , i am able streaming my movies/series to my smart tv though that happens only in my home. When i am out and wann...
- Dec 10, 2015
You shouldn't be using port 80. The admin panel uses https, not http. That usually uses port 443. Port 80 won't work unless you enable http admin access in the NAS (which you SHOULDN'T).
So you could forward 443.
But If you have other devices that you might want to access remotely (including your router's admin page) you can pick a different port to forward. For example 54321. You'd configure 54321 as the secondary https port in system->services. Forward 54321 in the router. And access the admin page as https://vkoukoutis.ddns.net:54321/admin
vkoukoutis
Dec 19, 2015Aspirant
It does at lan network settings
I did it to both just to be sure
- BrianL2Dec 22, 2015NETGEAR Employee Retired
Hi vkoukoutis,
Did that fix your problem? Does your ReadyNAS retain the same IP address assigned by your router?
I look forward to your response.
Kind regards,BrianL
NETGEAR Community Team
