herbg's avatar
herbg
Tutor
Jul 15, 2021
RN102 No Longer Accessible via Device Web Page
In recent days, I've experienced intermittent problems connecting with my RN102.  This is a backup NAS for my RN214 (which recently had it's own connectivity issues) so nothing runs on this NAS.  The...
  • Sandshark's avatar
    Sandshark
    Jul 15, 2021
    herbg wrote:
    I think I found the problem:  Another device on my home network (the camera security system) was using the same IP address.  The RN102 was given a static IP address under IPv4 so I'm surprised this happened.  I thought that once you set a static IP address, no other device could use it.
    Nope, that's not the way it works.  The router has no knowlege that you've set a static IP on a device -- it believes that IP to be available for assignment unless you conjfigure the static IP outside of the range you've allowed for DHCP in the router or reserve it.  That's one reason address reservation in the router is a better way to go (it actually makes no sense to do that and set a static IP, though I mentioned that possibility earlier).  The other advantage is that if you change the router and the new one uses a different subnet, you don't lose access to the NAS because it's on the wrong one.
ProSupport for Business
