Hansvandam's avatar
Hansvandam
RN102 power led keeps blinking after firmware update
Power led is blinking Happened during firmware upgrade 6.4.0 to 6.4.2 (I'm not completely sure of the version numbers) Done a USB recovery (to 6.4.2). It seems the recoery ended correctly (the syst...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 14, 2016
    Do you recall which services you are running under System > Settings > Services ?
    Which apps are you running?
    I have sent you a PM.
    Can you download the logs using RAIDar and send those in (see the Sending Logs link in my sig)?
ProSupport for Business
