Hansvandam
May 13, 2016Aspirant
RN102 power led keeps blinking after firmware update
Power led is blinking Happened during firmware upgrade 6.4.0 to 6.4.2 (I'm not completely sure of the version numbers) Done a USB recovery (to 6.4.2). It seems the recoery ended correctly (the syst...
- May 14, 2016
Do you recall which services you are running under System > Settings > Services ?
Which apps are you running?
I have sent you a PM.
Can you download the logs using RAIDar and send those in (see the Sending Logs link in my sig)?
Retired_Member
May 13, 2016Try to install RAIDar on your PC, to confirm if it "sees" it.
http://kb.netgear.com/app/answers/detail/a_id/20684#raidar
Tbh, there is way too many people using USB Boot Recovery, this should a last resort in exceptional situations. It's really rare the flash gets corrupt.
In your situation, there is a good chance you updated from 6.2.x to 6.4.x, and the quotas check needs to complete (which is very long in non optimimum volume configurations). Did you update from a 6.2.x to a 6.4.x?
Hansvandam
May 14, 2016Aspirant
I upgraded to 6.4.0 and then was prompted to upgrade to 6.4.2. Somewhere along that proces something went wrong.
I've checked with RAIDar. It sees the NAS. Status was System startup and now it is "management service is offline". Firmware is 6.4.2 and both disks have a green check.
I can see files in explorer but it takes very long.
- mdgm-ntgrMay 14, 2016NETGEAR Employee Retired
Can you download the logs using RAIDar and send those in (see the Sending Logs link in my sig)?- HansvandamMay 14, 2016Aspirant
I don't know which services and apps are running. I will send in the log. Thanks!
- HansvandamMay 21, 2016Aspirant
Thanks for all the help. All seems to be resolved!
- mdgm-ntgrMay 22, 2016NETGEAR Employee Retired
Glad it's resolved. I guess the system must have been taking a very long time to do something, perhaps the quota calculations or something else and it just needed to be given some time.
