adisinha
Jan 06, 2017Tutor
RN102 power led keeps blinking after firmware update
Hi, Tried updating firmware to the latest version and now the NAS has gone into a Coma. POWER LED is blinking since the firmware update started approx 2 hours ago. All other LEDs are on and solid...
Jan 06, 2017Guru - Experienced User
What firmware were you running before? Did you upgrade to 6.6.1 or something else?
- adisinhaJan 07, 2017Tutor
Sorry didnt pay attention before upgrading, assuming it is upgrading to the latest version. It had been a while since i last updated though.
Had this same issues a couple of years ago and had to have the NAS chassis replaced as the system would not recover even after doing a factory reset.
Upgraded to v6.6.0
A couple of reboots has resolved the issue for now. Thanks ! I can now login to the admin page and access the shares.
Will now setup backups to a usb hdd.
- FramerVJan 09, 2017NETGEAR Employee Retired
Hi adisinha,
Thank you for the update.
After your back-up, I would be suggesting that you do a firmware upgrade. There are bug fixes on it and I think it will be improving the ReadyNAS performance.
ReadyNAS OS 6 Software Version 6.6.1
