937carrera
Apr 27, 2019Aspirant
RN102 problems after upgrade to 6.10
I remotely upgraded one from 6.9.5 to 6.10 this week and lost remote access.
The dynamic DNS address is working correctly for all other services
When I had physical access I did the thre...
JohnCM_S
May 03, 2019NETGEAR Employee Retired
Hi 937carrera,
Can you provide to me the system logs so we can further check this? You may upload it to Google Drive then PM (private message) the download link.
937carrera
May 03, 2019Aspirant
John, PM sent
- kronos85May 03, 2019Aspirant
I have the exact same problem. After numerous tests I am sure that the firmware 6.10 has a problem with the second https port configuration
- JohnCM_SMay 10, 2019NETGEAR Employee Retired
Hi 937carrera, StephenB, kronos85,
The recently released OS 6.10.1-T32 (Beta 1) has a fix for this issue. You may download it here.
- 937carreraMay 10, 2019Aspirant
Thanks John,
I have downloaded and upgraded the firmware and the NAS has successfully rebooted.
Until I am at the remote location I cannot confirm that the issue is solved, but I expect to be able to do that over the next couple of days.
I have copied below the log from the reboot, it would appear that the GetUnitFileState error arising from 6.10.0 remains as an issue and continues to fill the logs
-- Reboot -- May 10 17:51:11 Nas-102 readynasd[2478]: readynasd log started May 10 17:51:15 Nas-102 readynasd[2478]: readynasd started. (restarted=0) May 10 17:51:45 Nas-102 readynasd[2478]: Failed to call method GetUnitFileState: No such file or directory May 10 17:51:47 Nas-102 readynasd[2478]: Using fan mode: quiet May 10 17:51:51 Nas-102 readynasd[2478]: Firmware was upgraded to 6.10.1-T32. May 10 17:51:51 Nas-102 readynasd[2478]: ReadyNASOS background service started. May 10 17:53:57 Nas-102 readynasd[2478]: Failed to call method GetUnitFileState: No such file or directory
I will post again when I have changed my router settings to test the forward
