937carrera
Apr 27, 2019Aspirant
RN102 problems after upgrade to 6.10
I remotely upgraded one from 6.9.5 to 6.10 this week and lost remote access.
The dynamic DNS address is working correctly for all other services
When I had physical access I did the thre...
937carrera
May 03, 2019Aspirant
John, PM sent
kronos85
I have the exact same problem. After numerous tests I am sure that the firmware 6.10 has a problem with the second https port configuration
- JohnCM_SMay 10, 2019NETGEAR Employee Retired
Hi 937carrera, StephenB, kronos85,
The recently released OS 6.10.1-T32 (Beta 1) has a fix for this issue. You may download it here.
- 937carreraMay 10, 2019Aspirant
Thanks John,
I have downloaded and upgraded the firmware and the NAS has successfully rebooted.
Until I am at the remote location I cannot confirm that the issue is solved, but I expect to be able to do that over the next couple of days.
I have copied below the log from the reboot, it would appear that the GetUnitFileState error arising from 6.10.0 remains as an issue and continues to fill the logs
-- Reboot -- May 10 17:51:11 Nas-102 readynasd[2478]: readynasd log started May 10 17:51:15 Nas-102 readynasd[2478]: readynasd started. (restarted=0) May 10 17:51:45 Nas-102 readynasd[2478]: Failed to call method GetUnitFileState: No such file or directory May 10 17:51:47 Nas-102 readynasd[2478]: Using fan mode: quiet May 10 17:51:51 Nas-102 readynasd[2478]: Firmware was upgraded to 6.10.1-T32. May 10 17:51:51 Nas-102 readynasd[2478]: ReadyNASOS background service started. May 10 17:53:57 Nas-102 readynasd[2478]: Failed to call method GetUnitFileState: No such file or directory
I will post again when I have changed my router settings to test the forward
- 937carreraMay 11, 2019Aspirant
I am happy to report that the Port 2 setting is now working again.
