JabbaTheCat
Aug 10, 2015Guide
RN102 setting Raid 0 to get 1+1 or 1&1
Just got a RN102 and would like to set up the two disks as either Raid 0 across both or two seperate network drives. Currently RN102 is building some Raid 1 setup with a few hours to go. Can I st...
vandermerwe
Aug 10, 2015Master
You can interrupt it, as long as you haven't put any data on it it will be OK. If you switch off Xraid and setup the volume you want as below, it will interrupt the build anyway.
To set up anything other than Xraid you need to switch off Xraid in the GUI, it's on the Volume tab.
Then select new volume to set up whatever you want.
I would definitely go for 1 volume on each drive. If you have a spanned volume then a single disk failure causes the whole volume's data to be lost.
Remember to consider how you are going to backup these volumes.
JabbaTheCat
Aug 10, 2015Guide
Just to say thank you to you both for your help, the drives are now visible to all machines on the network.
Regards
JTC
