theluke79
Jan 24, 2016Aspirant
RN102 Stuck accessing External USB 3 Hard Disk
Hi everybody, I have an RN102 6.4.1 2x3TB WD Red 1 external 2TB WD red in a USB 3 enclosure I use the external drive for Torrent and backup. Lately it has become more and more difficult a...
mdgm-ntgr
Jan 24, 2016NETGEAR Employee Retired
Have you checked the USB disk with your PC to see if there is a problem with it?
Which filesystem are you using on the USB disk
Which services and apps are you running on the NAS?
- BrianL2Jan 25, 2016NETGEAR Employee Retired
Hi theluke79,
Does this happen if you will connect the said external USB storage to another USB port? Perhaps test it with another USB storage to further isolate this problem.
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team- theluke79Jan 25, 2016Aspirant
Hello folks, on the RN102 only the Antivirus and BitTorrent are running, nothing else.
The 3TB USB is on a Linux partition, the FS used is UFSD. The disk health check SMART is succesful.
I changed the USB port and rebotted, it seems to be solved now, I will keep you posted.
Tell me please if there are other test to do
Hi theluke79,
Thanks for the positive feedback. If the issue persists, I suggest that you try to load the latest RC Firmware.
Kind regards,
BrianL
