baskunnen
Mar 01, 2016Aspirant
RN102 unreachable after firmware 6.4.2 update
Hello, Last week I updated the firmware of my 2 RN102s. One works fine, no problem, but the other one has serious network problems. I cannot reach the device via the folders on the computer and e...
- Mar 01, 2016
Hello baskunnen,
You're most welcome. You should thank StephenB, he's the one led you to the AV :)
Please feel free posting any comments, questions or suggestions, we appreciate your contribution to the community!
Mar 01, 2016Guru - Experienced User
If the AV service is enabled on either RN102, you should disable it for now.
If that doesn't resolve it, you will want to download the logs (either from the admin UI or via RAIDar 6.x).
baskunnen
thnx StephenB for your response.
Unfortunately I have no idea what you mean with the AV service.
JennC: Yes, it's visible in RAIDar. But by clicking the hyperlink to the folders, it keeps on scanning. I cannot get acces to the files.
best, Bas
- JennCMar 01, 2016NETGEAR Employee Retired
Hi baskunnen,
StephenB is referring to AntiVirus feature of the NAS.
- baskunnenMar 01, 2016Aspirant
Wow! That seems to work! (for now)
I disabled Antivirus and I have acces again.
But is it safe?
Hello baskunnen,
Yes it is safe, we recommend to disable this for the meantime. Eng'g team is developing a fix for this and we are expecting it to be released this March.
Hello baskunnen,
Can you try typing \\ then followed by the IP address of the NAS in the address bar of Windows explorer? How's the LED activities by the way?
