berni45
May 29, 2017Tutor
RN102: Upfrade fimware from 6.6.1 to 6.7.4
Hello Netgears Members I saw that there were in short intervalls multiple firmware updates for my RN102 (OS6). As per release notes: - ReadyNAS 102, 104, and 2120 must not be updated direct...
- May 29, 2017
Yes. You can update from 6.5.2 (or later) directly to 6.7.4. If your firmware is out of date when you open the web admin UI you should be prompted with the recommended update.
Updating your regular backup before updating the firmware is advisable as is downloading a copy of the logs.
mdgm-ntgr
May 29, 2017NETGEAR Employee Retired
berni45
May 29, 2017Tutor
Many thanks for your confirmation.
After a fresh backup, upgrade went well
Cheers
Bernard
