piet8stevens
Mar 18, 2020Aspirant
RN102 USB backup speed usb3 OS6.10.2
I have bought new backup HDD (WD Elements) for my RN102. Started backup of some 3TB but only getting speed of 12MB/s. HD is formatted EXT4. I saw a thread from 2016 talking about slow USB3 backup sp...
piet8stevens
Mar 19, 2020Aspirant
Hello, thank you for our reply.
The speeds I reported are from the back USB3 ports. I had the RN102 reformat the HDD to ext4.
When I connect the drive directly to my laptop (windows 10) via USB3, I get copy speeds between 10 and 210 MB/s, depending on file size. Here, the hdd is formatted NFS. In total, 6,305 items were copied, for a total of 64 GB in roughly 6 minutes (I looked at the PC clock, did not time the seconds), ie, roughly 180 MB/s.
I copy from an SSD on the laptop.
On the NAS, I have WD Red drives in raid 1. The HDD I copy to is a WD green one.
So, on the laptop, the speed is roughly 18x faster than on the NAS. That seems to be quite a factor!
Mar 20, 2020Guru - Experienced User
This was from the NAS? I'm guessing not, because the speed is too high there:
- a gigabit ethernet connection can't carry more than 120 MB/sec with any NAS
- The RN100 series isn't fast enough to deliver more than about 75 MB/s over gigabit ethernet.
So something isn't quite right with the measurement.
Assuming it was a local copy, I'd try doing a copy from the NAS to the USB drive, and see what performance you get. You could also try NasTester ( http://www.808.dk/?code-csharp-nas-performance ). The idea here is to check the performance of the RN102 itself.
FWIW, I don't recommend using ext formatting for backups unless you have another machine that supports ext. A backup you can't read isn't very useful.
- piet8stevensMar 20, 2020Aspirant
Thank you for your reply.
The 6,305 items copies were from the laptop to the backup drive connected directly to the laptop via usb3. Speed is roughly 180MB/s, i.e., a measure for what is possible over usb3, as per the recommendation in your first reply.
Using the same drive from the RN102 to the backup drive connected direclty via a USB3 on the back, it gives the 10-12MB/s
So, the question is why the usb3 on an RN102 for a direct copy is so slow.
- StephenBMar 20, 2020Guru - Experienced User
Yes. And one possible reason is that the RAID array is underperforming. That's why I suggested that you test the transfer speed of the NAS itself.
Sorry, you are right - I should have run the test first before replying.
From my Windows 10 laptop, I have run the test over my LAN.
These are the results using the default file size and iterations (400 and 5 respectively):
Iteration 1: 11.61 MB/sec
Iteration 2: 10.70 MB/sec
Iteration 3: 10.60 MB/sec
Iteration 4: 11.46 MB/sec
Iteration 5: 11.06 MB/sec
Average (W): 11.09 MB/sec
Iteration 1: 10.54 MB/sec
Iteration 2: 10.10 MB/sec
Iteration 3: 10.57 MB/sec
Iteration 4: 10.80 MB/sec
Iteration 5: 9.89 MB/sec
Average (R): 10.38 MB/sec
So, it seems it is an issue with RAID read/write times, rather than a usb3 issue. Thank you for providing advice and the link to the testing software.
What can I do about RAID read/write times?
Note: re. my LAN, I used iperf3 to check speed across the network to the NAS, and had about 750-760 MB/s between my desktop and the 2 RN102s, so the speed is not restricted by the LAN. I report between desktop and NAS because I run Ubuntu on my desktop and I have not installed iperf3 on my windows laptop. but the desktop and laptop are connected to the same switch on the network.
