TonyT3ch
Feb 12, 2022Aspirant
RN10200 - Not showing Admin Web UI after Factory Reset
I have a RN10200 and was doing a factory reset on the device and the Admin Web UI is not responding. The device is pingable and I can see it in the RAIDar App but the front end ui doesn't load.
Feb 13, 2022Guru - Experienced User
What drives are you using?
How long has it been non-responsive?
- TonyT3chFeb 13, 2022Aspirant
I have 2 - 1TB Drives and after performing a factory reset the Admin Web UI stopped working. We tried factory resetting it for a second time but encountered the same results. This has been happening since yesterday, we can ping and the device is visible using the RAIDar APP.
- StephenBFeb 13, 2022Guru - Experienced User
What manufacturer/model?
Can you download the log zip with RAIDar?
Can you access the shares with File Explorer (or Finder) after the web UI stops working? Or does that fail also?
Netgear RN10221D-100NAS
How can do I do this?
It was factory reset, so no share have been configured.
