TonyT3ch
Feb 12, 2022Aspirant
RN10200 - Not showing Admin Web UI after Factory Reset
I have a RN10200 and was doing a factory reset on the device and the Admin Web UI is not responding. The device is pingable and I can see it in the RAIDar App but the front end ui doesn't load.
Feb 13, 2022Guru - Experienced User
What drives are you using?
How long has it been non-responsive?
TonyT3ch
Feb 13, 2022Aspirant
I have 2 - 1TB Drives and after performing a factory reset the Admin Web UI stopped working. We tried factory resetting it for a second time but encountered the same results. This has been happening since yesterday, we can ping and the device is visible using the RAIDar APP.
- StephenBFeb 13, 2022Guru - Experienced User
What manufacturer/model?
Can you download the log zip with RAIDar?
Can you access the shares with File Explorer (or Finder) after the web UI stops working? Or does that fail also?
- TonyT3chFeb 13, 2022Aspirant
Netgear RN10221D-100NAS
How can do I do this?
It was factory reset, so no share have been configured.
- StephenBFeb 14, 2022Guru - Experienced User
Default shares should still be there (assuming the volume was created)
TonyT3ch wrote:>>>Can you download the log zip with RAIDar?
