sanjeewakuku
Dec 13, 2017Aspirant
RN10200 not visible
hi, power LED on. strat up blink few second only. network port green color LED blinking. but no ip or discover to RAIDar how to pix that
- Dec 26, 2017
i have using usbrecovery.v2.0.T14.support. USB flash and problem solved
Dec 14, 2017Guru - Experienced User
Is this a new system setup?
Are there disks installed in the RN102?
sanjeewakuku
Dec 15, 2017Aspirant
StephenB wrote:Is this a new system setup?
no. i have take ip image from my router.
no didn't install disk
- msqDec 15, 2017Apprentice
I think it will not pick up IP address unless there is at least one disk inserted.
- sanjeewakukuDec 15, 2017Aspirant
i think OS not boot. i have plug the power after power LED blink few second and LED stable on. can i get advice how to install OS using USB flash drive
Please try the following:
- power off the device
- inster one clean drive
- boot it again
- check on your router or RAIDar what is the IP of this router
