MH0199
Mar 22, 2017Aspirant
RN10222D Power Light (blue) Slowly Flashing
Hi. our RN10222D is displaying a blinking power light and no activity on the Disk1 and 2 LEDs. before this condition, we at least saw Disk1 with solid blue and disk 2 blinking light. I'm not sure ...
MH0199
I upgraded to 6.2.5. RAIDr interface says Drivers are okay...I hope this thing comes back to life soon. I'm going to try to upgrade on until i'm on the latest version. See what happens. Power light just keeps blinking slowly same way.
I hope someone else has seen this before and can offer some input.
mdgm-ntgr
Mar 22, 2017NETGEAR Employee Retired
To update from 6.2.5 to 6.5.2 you'd need to use a workaround
- MH0199Mar 22, 2017Aspirant
It got worse after upgrading to 6.2.5. Now I can't even get to admin page to do anything else. I did a factory (O.S. Reinstall) because I have data on these drives that I desperately need. Now I see the IP address has changed, but the firmware is still 6.2.5...how is that possible? Shouldn't this be on older firmware now?
I'm also open to pay for support and get this resolved if need be...how do I contact support if there's hope to revive this unit?
By the way, inorder for me to follow the workaround, I'd need access to the admin page as the instruction state. I can't do that anymore :(
- mdgm-ntgrMar 22, 2017NETGEAR Employee Retired
I guess you didn't get my PM?
Support does have various contracts available. The cheapest is per incident which is about $75 USD, I think. Support can confirm what the current cost is.When you update the firmware, the firmware on the flash is updated and the firmware is installed onto the disks.
OS Re-install (resets admin password, some network settings and installs OS over the top of itself) and Factory Default (wipes all data, settings, everything) use the firmware on the flash.
