brianjmc1
Jan 16, 2017Tutor
RN104 - Out of Memory 36c
RN104, did an update to 6.6 and now the system is getting Out of Memeory 36c. I was fianlly able to get it intoread only mode, long enought to grab the logs. Any help would be greatly appreciated.
brianjmc1
Jan 21, 2017Tutor
6.6.1 - just sent the logs, i can get it into Read only mode, but freezes in 5-10 minutes...
Thanks for your time,
Brian
mdgm-ntgr
Jan 22, 2017NETGEAR Employee Retired
Just disabled quotas. We'll see if this makes a difference on your system.
- alfacomFeb 23, 2017Aspirant
Свободно менее 20% от емкости тома media. Производительность тома media снизится, если резервная емкость будет заполнена. NETGEAR рекомендует увеличить емкость тома, чтобы избежать снижения производительности
Том: Заполнение системного тома root составляет 85%. В обычных условиях такое состояние возникать не должно. Свяжитесь с технической поддержкой.
but i dont have such Volume
- brianjmc1Feb 23, 2017Tutor
You are going to rack your brains on this.....I tried EVERYTHING, nothing worked. Only way it was fixed, a tech from this forum, ask for permission and remoted to the box, he cleared the quotas and rebooted. It was using 4tb and had 4tb free... the tech was mdgm and he was GREAT!!!!
good luck...
