brianjmc1
Jan 16, 2017Tutor
RN104 - Out of Memory 36c
RN104, did an update to 6.6 and now the system is getting Out of Memeory 36c. I was fianlly able to get it intoread only mode, long enought to grab the logs. Any help would be greatly appreciated.
mdgm-ntgr
Jan 22, 2017NETGEAR Employee Retired
Just disabled quotas. We'll see if this makes a difference on your system.
alfacom
Feb 23, 2017Aspirant
Свободно менее 20% от емкости тома media. Производительность тома media снизится, если резервная емкость будет заполнена. NETGEAR рекомендует увеличить емкость тома, чтобы избежать снижения производительности
- alfacomFeb 23, 2017Aspirant
Том: Заполнение системного тома root составляет 85%. В обычных условиях такое состояние возникать не должно. Свяжитесь с технической поддержкой.
but i dont have such Volume
- brianjmc1Feb 23, 2017Tutor
You are going to rack your brains on this.....I tried EVERYTHING, nothing worked. Only way it was fixed, a tech from this forum, ask for permission and remoted to the box, he cleared the quotas and rebooted. It was using 4tb and had 4tb free... the tech was mdgm and he was GREAT!!!!
good luck...
How clear quotas?
- StephenBFeb 23, 2017Guru - Experienced User
You do have a system volume - usually called the OS partition here. You can't normally see it, but the OS is installed on the disks.
I do suggest using paid netgear support to deal with your out-of-memory issue (and they can also resolve the issue with a full system volume).
If you are running 6.6.1 firmware (and have access to the web ui) then I suggest disabling the antivirus service.
If you can download the log zip file, you can look at the system data usage. Volume.log has a section with a df . -h header. The first few entries (up to and including the tmpfs entries) are used by the system itself, and generally shouldn't be very full - no more than ~20%.
Pools
Pool root:
Device: /dev/md0
Node: 9:0
HostID: 0e34fa56 (native)
UUID: 0bd80197-f7f9-49f1-8c43-80767bda63ce
Mount point: /
Size: 3882076KB (3 GB)
Available: 376788KB (0 GB)
RAID Level: 1
State: redundant
Action: idle
Flags 0xA8
Type: ext4
RAIDs:
md0
Level: 1
Action: idle
Members: 4
Disks:
sdd:
HostID: 0e34fa56
Flags: 0x0
Size: 11721045168 (5589 GB)
Free: 14
Controller 0
Channel: 0
Model: TOSHIBA_HDWE160
Serial: 3661K850F56D
Firmware: FS2A
RPM: 7200
SMART data
Latest Self Test: Passedsdc:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 1
Serial: 3664K41XF56D
Firmware: FS2A
RPM: 7200
SMART data
Latest Self Test: Passedsdb:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 2
Serial: 3661K84WF56D
Firmware: FS2A
RPM: 7200
SMART data
Latest Self Test: Passedsda:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 3
Serial: 3661K851F56D
Firmware: FS2A
RPM: 7200
SMART data
Latest Self Test: PassedPool swap:
Device: /dev/md1
Node: 9:1
UUID: d5b50a0c-8ce2-449f-bdb5-eec267d0ad25
Mount point: none
Size: 0KB (0 GB)
Available: 0KB (0 GB)
RAID Level: 6
State: inactive
Action: idle
Flags 0xA8
Type: swap
RAIDs:
md1
Level: 6
Action: idle
Members: 4
Disks:
sdd:
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 0
Firmware: FS2A
RPM: 7200
SMART data
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 1
Firmware: FS2A
RPM: 7200
SMART data
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 2
Firmware: FS2A
RPM: 7200
SMART data
HostID: 0e34fa56
Flags: 0x0
Free: 14
Controller 0
Channel: 3
Firmware: FS2A
RPM: 7200
SMART data
