WiredRacing
Mar 14, 2019Aspirant
RN104 - Really Slow Copy Speeds
Hey guys, I'm copying a share from one volume to a new volume through SSH using MC (Midnight Commander) and I'm getting an avg of 6.33MB/s. Going to take 35mins or so to copy 14GB.
I know this...
Mar 15, 2019Guru - Experienced User
WiredRacing wrote:
Whenever this finishes I'll run the performance test I see others run.
It'd be good to test the read and write speeds on each drive independently - using dd, and /dev/zero as either the source or destination.
WiredRacing
Mar 15, 2019Aspirant
OKAY THIS MAKES ZERO SENSE
For $#!ts and Giggles I tried copying from one share to another on my PC (Win 10), again from share to share. I'm getting 30-40MB/s! It'll copy 20GB in 9-10mins. And this is while one of my backup jobs (2.3TB of data in that share, has only managed about 10% of it's job in 5 hours) is still going.
What is going on that copying within linux, on the device itself, is 1/3rd the speed?
Obviously, I'm going to copy the rest of the volume... over the network (whhhhaaaat?).
- HopchenMar 15, 2019Prodigy
This is interesting. I have heard about this type of behaviour before.
I wonder if the NAS struggles with memory when copying like this.
Try to rsync it instead, from the CLI. Is performance better then?
Also, what does a dd test reveal?
cd into one of your shares and then dd a file. # dd if=/dev/zero of=bigfile.bin bs=4M count=250
Here is an example from my RN422. It is of course faster than your NAS, but for the purpose of demonstration...
root@Datastore:/data/Public# dd if=/dev/zero of=bigfile.bin bs=4M count=250 250+0 records in 250+0 records out 1048576000 bytes (1.0 GB, 1000 MiB) copied, 5.20838 s, 201 MB/s
- WiredRacingMar 15, 2019Aspirant
It's still handling that other backup job, so I haven't run any benchmarks on it.
Looking at 'top' I've got
readynasd taking up 20-25% of the cpu
smbd taking up 25-28% (I'm copying a file through windows, only between 12-18mb/s right now)
kswapd0 taking up 12-14%
fvbackup taking 12-14% (still that one share backup, probably somewhere between 6 to 10mb/s)
Of 508732 total KiB of Mem, there's around 1800-25000 free.
minidlnad is using about 70% of the memory, but not much cpu.
- StephenBMar 16, 2019Guru - Experienced User
You could try disabling the DLNA service and see if that makes any difference.
- WiredRacingMar 16, 2019Aspirant
The 'minidlnad' processed eventually dropped off 'top' and went down to sub 6%. Though curiously the amount of memory in use stayed the same.
When my SMB copy stopped, I stopped readynasd (as it was always trying to take up 100% of the cpu) and then started it and it started to behave "normally" (only spiking when using the management console). However, I tried another copy within midnight commander, large file, and it still didn't go over 10mb/s while the SMB copy with readynasd under control and no other backup process happening would top out in the mid 50's (generally hanging around in the mid 40's). smbd around migh 50 to mid 60% cpu, which kicks up kswapd0 to low teens. 3 kworker processes, usually 2 of them equal 10%.
When I sort 'top' by mem%, 'minidlnad' it's the highest (at 5.6%) but no other process seems to be using a lot of memory despite 480000 used and only ~30000 free. The swap looks much better now though, only 10,416 used. 3-5 running tasks, 187(!) sleeping (0 stopped or zombie).
So yeah this is still quite odd why smb copies so much faster. Haven't rebooted yet, ALMOST done migrating all my data over. Just a few more hours now.
- WiredRacingMar 17, 2019Aspirant
So, after powering down. Moving my new drive that I was copying all this data to into another slot, turning it back on. Then shutting down again and reinstalling an exported 2-disk volume, turning it back on to verify it worked. Then exporting it again, removing it. Putting two other disks in, creating a RAID 0 volume of those and manually editing smb.conf (which was not loading due to "smb encryption = (null)"). I created some backup jobs to backup data from the Bay 1 drive to this new array and I'mgetting an avg of 44mb/s through the management console and using the backup jobs.
So it appears, somewhere in that process, part of my problem(s) corrected themselves.
Once the backups are done, I'll run the various commands and tests mentioned here and post the results for future reference.
Going to probably need to start another thread on the SMB config issue because as soon as I reboot, it will overwrite my change, so somewhere else in the system is some thing else that needs to change, or I need help to write a script to update and re-try 'systemctl start smb' after a minute or two after booting. Anyhow, separate issue (but part of the odyssey of this single drive upgrade project).
