Lacesso
Jun 04, 2016Aspirant
RN104 6.5.0 - SMB write broken (READ is fine), FTP times out, HTTP upload impossibly slow 180kbps
RN104 6.5.0 Windows 10 SMB writes creates empty files of the same size of actual files. SMB read is fine FTP just times out on reading the directory info HTTP upload which is what I am left ...
Lacesso
Hi
Thanks for reply.
I think this is an issue with the insider version of w10 as I have no issues on other networked devices. Ftr though it is all shares and WiFi or cable.
I will look for a fix later and post if I find one.
Thanks for reply.
- JennCJun 07, 2016NETGEAR Employee Retired
Hello Lacesso,
You're welcome. You might also want to disable firewall security software on the computer. And maybe restarting SMB?
