RN104-Gumboe
May 22, 2020Aspirant
RN104 automatically powering on
Hi, my RN104 auto powered up the other day while not being plugged into the ethernet switch. It's happened a few times previously but it was plugged into a Netgear 16 port unmanaged gigabit switch w...
RN104-Gumboe
Thanks, it's not plugged into a UPS. And most of the time it's not even switched on. It probably gets switched on about a dozen times a year. The power brick and the ethernet cable are always plugged in although for the last couple of months the switch end of the ethernet cable has been left unplugged. Power blips, hmm, not sure. We've got some picky kit here that I would expect to also show signs of an outage no matter how brief and I've not had a power blip here since before I got the RN104.
Are there any logs which I could find by SSHing onto the unit which would help to track down what this might be definitively?
Not sure about the power issue you mentioned so I'd better make sure I've got good backups. Just in case.
If the unit did die, what do you think would be my chances of getting the data off the drives either with or without a replacement RN104 from ebay? The drives aren't reporting any issues.
Sandshark
May 22, 2020Sensei
RN104-Gumboe wrote:Thanks, it's not plugged into a UPS. And most of the time it's not even switched on. It probably gets switched on about a dozen times a year. The power brick and the ethernet cable are always plugged in although for the last couple of months the switch end of the ethernet cable has been left unplugged. Power blips, hmm, not sure. We've got some picky kit here that I would expect to also show signs of an outage no matter how brief and I've not had a power blip here since before I got the RN104.
I can understand not having a UPS with so little use. But it does make a power droop #1 on my list of suspects. If there is a nearby UPS, you might want to plug it in there, even if the NAS is not set up to monitor it. If the problem goes away, you've found the culpret.
Unfortunately not. The NAS has no idea of what awakened it.
That's always a good idea, anyway. If you start having problems turning the unit on or off or with the Ethernet connection, then those are other signs of this issue.
Very high likelyhood of recovery by just moving the drives to a new ReadyNAS. But not high enough to risk important data by not having a backup unless the NAS already is just a backup (as opposed to sole archival)). The +5VSB isn't used for anything that's likely to take down your volume. If it did go poof during a file transfer, the currently transferring file would likely be corrupted, but that's aboiut it. If it was the whole power brick, then the volumne could be corrupted. But that's not high on my list of suispects.
- StephenBMay 23, 2020Guru - Experienced User
Sandshark wrote:
I can understand not having a UPS with so little use. But it does make a power droop #1 on my list of suspects. If there is a nearby UPS, you might want to plug it in there, even if the NAS is not set up to monitor it. If the problem goes away, you've found the culpret.FWIW, my RN102 is also not on a UPS (it has no data on it, I only use it for occasional testing). Power droop is a possibility, though I haven't seen any correlation with power glitches I've noticed.
- RN104-GumboeJul 16, 2020Aspirant
It's odd, I really wondered if there was a way I could enable SSH, then SSH into the unit and find a log file, syslog or something like that which might shed some light on the situation. I even wondered if the unit was responding to a WOL request but from one of the previous responses it seems as though it's a complete mystery and there's no way to tell what's happened or what I can keep an eye on. I did wonder whether it was possible the unit had somehow been infected with some malware that set a date and time for a power on and then start dumping data somewhere.
Can you imagine coming downstairs early one morning and finding your TV or washing machine on and having to shrug it off with 'oh well that's one of those things'.
- SandsharkJul 16, 2020Sensei
The NAS has no way of knowing how it was turned on, so there is no log you can examine. Is your NAS on an UPS? A power interruption, even very short, can cause your NAS to power on once power is restored if it's not held up by an UPS. If that's not it, a fault in the power-on circuit or the power to it can also cause it. The external supply could be the issue, but I think it's unlikely.
