RN104-Gumboe
May 22, 2020Aspirant
RN104 automatically powering on
Hi, my RN104 auto powered up the other day while not being plugged into the ethernet switch. It's happened a few times previously but it was plugged into a Netgear 16 port unmanaged gigabit switch w...
RN104-Gumboe
Jul 16, 2020Aspirant
It's odd, I really wondered if there was a way I could enable SSH, then SSH into the unit and find a log file, syslog or something like that which might shed some light on the situation. I even wondered if the unit was responding to a WOL request but from one of the previous responses it seems as though it's a complete mystery and there's no way to tell what's happened or what I can keep an eye on. I did wonder whether it was possible the unit had somehow been infected with some malware that set a date and time for a power on and then start dumping data somewhere.
Can you imagine coming downstairs early one morning and finding your TV or washing machine on and having to shrug it off with 'oh well that's one of those things'.
Sandshark
Jul 16, 2020Sensei
The NAS has no way of knowing how it was turned on, so there is no log you can examine. Is your NAS on an UPS? A power interruption, even very short, can cause your NAS to power on once power is restored if it's not held up by an UPS. If that's not it, a fault in the power-on circuit or the power to it can also cause it. The external supply could be the issue, but I think it's unlikely.
- StephenBJul 16, 2020Guru - Experienced User
Have you scheduled any maintenance in the maintenance schedule on the volume wheel? The last time I discovered my RN102 turned on, it was doing a scrub.
- RN104-GumboeJul 17, 2020Aspirant
I know it's unusual but my NAS is not usually turned on. 99% of the time it's off.
It's not plugged into a UPS. It just sits on the edge of my desk and I turn it on occasionally.
My PC is always on and is set to not power on after a power outage. If there had been a power blip causing the power to drop and come back and then causing the NAS to come back on then my PC would be off. So it's not that.
No there's nothing scheduled on the NAS, I don't have any apps installed on it and there's nothing that automatically tries to save to my NAS.
- StephenBJul 17, 2020Guru - Experienced User
A practical solution is to connect the NAS to a power strip, and power down the power strip after you shut it off. A bit inconvenient, but it certainly will avoid the problem.
If the NAS generally isn't powered up for long, you could also create a power schedule to turn it off at a set time (say 6 am). Then if it does power up, it won't stay up for longer than a day.
- RN104-GumboeJul 18, 2020Aspirant
StephenB wrote:A practical solution is to connect the NAS to a power strip, and power down the power strip after you shut it off. A bit inconvenient, but it certainly will avoid the problem.
Not sure I understand why you're suggesting options for powering up and down the NAS? I don't need to do this, I'm ok with powering it on and off manually when I want.
My original question is why would my NAS power up all on it's own?
Responses so far have suggested it may be a faulty power connector, or a scheduled job. I don't believe it's either of those, I've checked and there are no scheduled jobs and wrt the power connector it's not damaged and it's not been stretched/stained. It's been inserted into the back of the RN104 maybe twice in the years I've had it.
When no one was able to suggest anything else I asked if there were any log files that I could look at by SSHing into my RN104. Reply was that the RN104 doesn't record how it's been powered on. I'm wondering if there's anything like an auth.log or syslog that I could take a look at but it doesn't look like it.
- SandsharkJul 18, 2020Sensei
The suggestion StephenB is making is to prevent it from powering up on it's own.
Even when the NAS is "off", there is an internal standby voltage that is always on whenever the external power is applied, as it powers the power-on circuit and WoL. By putting a switched power strip in, you remove the power from that circuit as well as the rest of the NAS. In addition to stopping the annoyance of the NAS turning itself on, that could affect the life of your NAS. Issues with the standby voltage regulation (from the 12V that comes from the power brick) or the power on circuit could be your issue. But the rub is that without knowing the root cause, it could be just as likely that adding power cycles to those circuits would reduce their lifespan as much or more than reducing power-on time would increase it.
Is WoL enabled on the NAS? Since you apparently don't use it, disabling that could help.
- StephenBJul 18, 2020Guru - Experienced User
Correct. Using a switched power strip (or even just unplugging it) ensures that it can't power up when you don't want it to. The other idea would just make sure it shuts down reasonably promptly (in case you don't notice that it's on).
I agree with Sandshark that w/o knowing the root cause it's hard to say how this would effect the NAS life.
The logs might be able to tell you why the NAS powers down. But not why it powers up. There's nothing in the system logs that can tell you that.
- RN104-GumboeJul 19, 2020Aspirant
Sandshark wrote:The suggestion StephenB is making is to prevent it from powering up on it's own.
Ok thanks, I understand what StephenB was saying now and thanks to StephenB. I'll definitely look into getting a switched power strip.
WoL is not enabled on the NAS and there are no scheduled jobs running. I've had it power up on it's own about 3 or 4 times in the last 6 months. On one occasion it even powered up at some point after I'd gone to bed without the ethernet cable being plugged into my Netgear GS116 switch which to me implies it's something on the RN104 causing the unit to power up on it's own rather than something on my network.
Thanks, how do I access the logs?
- SandsharkJul 19, 2020Sensei
From the System/Logs page of the admin GUI, select "Download Logs".
