zdendo
Apr 17, 2015Aspirant
RN104 Could not properly extract, fireware checksum error
Hi, I've got a little problem with my NAS and an upgrade to 6.2.2.(4x1T hdd in RAID10 - 10% free space in time of upgrade - update) After restart LED shows this information: 1. Booting... 2. Che...
RX
Apr 17, 2015Luminary
Since you already did a factory reset on your RN104, try to initially set it up with only 1 disk inside. Try these steps:
1. Insert 1 disk then perform a factory reset.
2. Download again the FW v6.2.2 from this link below (its possible that what you have downloaded earlier is corrupted that is why it failed to update):
http://www.downloads.netgear.com/files/ ... .2-arm.zip
Note: Be sure to unzip it before uploading it to your NAS.
3. Try to update the FW to v6.2.2 and check if it will be successful.
