XAffi
Dec 21, 2015Aspirant
RN104 crashing during resync
Hi. 3 days ago my RN104 with firmware 6.4.1 gets unaccessable and I had to pull the plug. This caused the device to resync the 4 WD red harddiscs. Today at almost 90% the device gets again unaccessa...
- Jan 01, 2016
Hi.
I would say the update of the last beta fixed my issue... Whatever reason was behind is gone.
Thxs. & happy new year.
Norbert
BrianL2
Dec 21, 2015NETGEAR Employee Retired
HI XAffi,
Check the status or the health of each NAS drive that you have. Connect them on a PC and run the manufacturer's disk diagnostic tool.
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
XAffi
Dec 22, 2015Aspirant
Thanks Brian for your response. According the SMART status provided in the logs the 4 drives seems "OK". Shall I really shut down the NAS and stop the re-sync or would you recommend to wait if it "stops workgin" again?
Thanks Norbert.
- Nik_BDec 22, 2015Aspirant
Hi, I am interested in this answer - having the same problem. Since 6.4.1 firmware upgrade the RN104 crashes so won't go to admin page, shut down or reboot. If I pull the power it boots, takes 30 hours to resync and then as soon as it completes it crashes again... Help!
