XAffi
Dec 21, 2015Aspirant
RN104 crashing during resync
Hi. 3 days ago my RN104 with firmware 6.4.1 gets unaccessable and I had to pull the plug. This caused the device to resync the 4 WD red harddiscs. Today at almost 90% the device gets again unaccessa...
- Jan 01, 2016
Hi.
I would say the update of the last beta fixed my issue... Whatever reason was behind is gone.
Thxs. & happy new year.
Norbert
XAffi
Dec 22, 2015Aspirant
Thanks Brian for your response. According the SMART status provided in the logs the 4 drives seems "OK". Shall I really shut down the NAS and stop the re-sync or would you recommend to wait if it "stops workgin" again?
Thanks Norbert.
Nik_B
Hi, I am interested in this answer - having the same problem. Since 6.4.1 firmware upgrade the RN104 crashes so won't go to admin page, shut down or reboot. If I pull the power it boots, takes 30 hours to resync and then as soon as it completes it crashes again... Help!
