IndyMag
Dec 09, 2014Aspirant
RN104 eSATA Issues #24305721
Hi everyone, I have several ReadyNAS units at work (some Ultra/Plus units and an RN314). I just purchased an RN104 for home use, and am having issues getting it to work with an external eSATA enclosu...
Dec 16, 2014Guru - Experienced User
What you want to do is prevent expansion, and access the disks in jbod mode. if the RN104 is confused about these drives being external (which I think it is), then flexraid would be the obvious thing to try.
But you've done that... Did you select one drive at a time when you said "new volume". Also, I think "new" means "new" it would end up btrfs, and not ntfs.
