LH74
Apr 07, 2017Aspirant
RN104 Fail to Startup
So everything has been working well for a while other than a few small issues, so decided to upgrade to 6.7.0. Upgrade completed quickly and without issues and seemed to resolve some of the smaller ...
LH74
I will look at that now.
Is it worth doing an OS Reinstall or will I lose the data if I do that?
I am able to get SSH access direct to the box and can login if that helps?
LH74
Further news.
I was able to restart the NAS from the command prompt. Gets up to 99% and sits like that for many minutes.
During this time, admin page and Shares are active.
The Display channges to "Fail to Start" and at that point the Admin Page stops being avaialble able to shares disconnect.
Still thinking an OS Reinstall is whats needed? but again, will this mean I will lose data?
- StephenBApr 07, 2017Guru - Experienced User
An OS reinstall shouldn't hurt your data. It will reset the admin password of your NAS to password, and it will reset the network interface to use DHCP (which is the default).
Though I don't think it is likely to solve your problem.
