tipster71
Jul 26, 2017Guide
RN104 Freeze with "ext4_writepage+478" error
Hi All, So yesterday I got home to find my RN104 had frozen, with the error "ext4_writepage+478" displayed on the front. It would respond to pings on the network, but all other access was unrespo...
tipster71
Aug 16, 2017Guide
Hi JennC,
Any update on this at all? I see that 6.8.0 has been released, but there is no specific mention of fixes related to this. Be great to hear any findings from the logs.
Cheers,
Nick
mdgm-ntgr
Sep 04, 2017NETGEAR Employee Retired
So you still have this problem? Can you send a fresh set of logs?
- tipster71Sep 05, 2017Guide
Hi MDGM,
No I havent had the issue again thankfully (touching wood furiously) but I am sure some of the posters above would like some help. I am hping my issue was a one off, and I am waiting for 6.8.1 before I lift myself to the next level.
Cheers,
Nick
- mdgm-ntgrMar 08, 2018NETGEAR Employee Retired
Do you still see this on 6.9.3? If so can you send in fresh logs (see the Sending Logs link in my sig)?
- mp_ukSep 10, 2017Aspirant
I think so. I've been hacking around it by scheduling a 1-hour daily shutdown, then using an external timer power switch to power-cycle it in that window, ensuring that any lockup failure gets fixed before all the scheduled daily backups run. This means that I haven't actually seen the failure, but I have seen something similar in the logs - see kernel.log Sep 07 08:20:36.
I've disabled the scheduled power-off, so I'll keep an eye on it and grab logs if it hangs again. Thanks for your help.
- mp_ukSep 17, 2017Aspirant
My device failed again, now with 6.8.0 firmware. Looks like it may have failed during an rsync backup operation.
For now, I'm going back to my scheduled power cut to ensure it recovers from this state, but any advice on how to remedy this would be very much appreciated. Shouldn't really have to do a scheduled daily power-cycle to ensure reliable operation of backups.
- mdgm-ntgrSep 17, 2017NETGEAR Employee Retired
So the Rsync backup operation is to a USB disk formatted with EXT4?
If it is a backup to a USB disk, does the USB disk have its own external power supply?
Is the NAS being used for other tasks than the backup when that's running?
- BrianM1950Sep 13, 2017Aspirant
Hi,
I'm running 6.8.0 firmware and have 2xWD Red 3GB and 2xWD Red 4GB drives running as a single X-RAID volume.
My NAS froze this afternoon with the same message displayed, except the page number was '+475'.
As the Power button did nothing, I removed the power from the unit, then re-powered it. The NAS booted, seemingly normally, but displayed no messages about rebuilding although the disks were extremely busy for a while after the reboot. At the time of the freeze, I was using Sync2Folders on my iMac to copy the <home>/Pictures/ folder up to the NAS. The copy failed on the 'Photos Library.photoslibrary' file, if that is any help.
I have taken the liberty of sending the NAS logs.
- Jan 17, 2024Retired_Member
