Riehmc
Aug 03, 2021Aspirant
RN104 GUI slow or not loading
Last update was a month ago to the newest 6.10.5. Now the GUI won't load after logging in, page just tries to load, but SSH works just fine. I've tried powering off completely and also warm rebooti...
Aug 10, 2021Guru - Experienced User
Riehmc wrote:
How do I check to see if the USB is mounted?
lsblk should show you. Normally the internal disks would be sda, sdb, sdc, and sdd. The mount point would be the last entry on the line.
Riehmc wrote:
I want to use the cp command to copy the whole /data folder to the backtop usb. What is the command?
If the USB device is mounted as /usbdrive then you'd want
cp -R /data/* /usbdrive/data
Riehmc
Aug 10, 2021Aspirant
Guessing this is the issue:
root@NAS:/dev# lsblk
sde 8:64 0 4.6T 0 disk
├─sde1 8:65 0 200M 0 part
└─sde2 8:66 0 4.6T 0 part
root@NAS:/# mount /dev/sde2 /mnt
mount: unknown filesystem type 'exfat'
