77PALE77
Jul 24, 2023Apprentice
RN104 Is manual install of 6.10.9 safe?
Hi everyone, my RN104 says its firmware 6.10.8 is up to date, even if I search for updates no update ion any kind s available; but I know there is a 6.10.9 release. Is it safe to upload it on the N...
Sandshark
Jul 24, 2023Sensei
Yes, it is safe. Netgear always releases for local installation before putting it on the update server. But this time they are being even slower than usual, likely because most of the folks who supported ReadyNAS no longer do.
- 77PALE77Jul 24, 2023Apprentice
Thanks a lot it worked fine
- EtarshaAug 02, 2023AspirantHello, I have the RN214 and tried to do the manual update but I kept getting the "unrecognized server error" when I tried to upload the image. Would you mind walking through the steps you took to manually install?
I tried uploading the arm, and the x86, both as .zips and then just the .img files and every time it immediately failed. Did you instead overwrite the files? Did you install it in a way other than through the admin page settings?
Thanks in advance- NiveditaP3Aug 02, 2023NETGEAR Expert
Hello Etarsha
Please find the steps for upgrading or downgrading the Firmware :
1.Download the required firmware image from google browser compatible to your ReadyNAS model.
2.Open the NAS admin UI
3.Navigate to system >> settings >> update
4.Click on Install firmware >> browse the downloaded firmware
5.Click on upload.Link for reference : https://kb.netgear.com/000065653/ReadyNAS-OS-Software-Version-6-10-9
Please try upload the .img file from the arm based firmware for RN214.
Have a lovely day,
Nivedita Pa
Netgear Team
