77PALE77
Jul 24, 2023Apprentice
RN104 Is manual install of 6.10.9 safe?
Hi everyone, my RN104 says its firmware 6.10.8 is up to date, even if I search for updates no update ion any kind s available; but I know there is a 6.10.9 release. Is it safe to upload it on the N...
Etarsha
Aug 03, 2023Aspirant
Hello, I have the RN214 and tried to do the manual update but I kept getting the "unrecognized server error" when I tried to upload the image. Would you mind walking through the steps you took to manually install?
I tried uploading the arm, and the x86, both as .zips and then just the .img files and every time it immediately failed. Did you instead overwrite the files? Did you install it in a way other than through the admin page settings?
Thanks in advance
Thanks in advance
77PALE77
Aug 03, 2023Apprentice
Hi,
surely I downloaded the file , unzipped it and uploaded it from the admin page; as far as I can remember, I used the .img file.
Now I am not home and I canât tell you more about it. Did you read the .readme file about direct update from older os version?
- NiveditaP3Aug 03, 2023NETGEAR Expert
Hello 77PALE77
Could you please try downloading and installing the .img file again.
Please make sure your ReadyNAS is getting proper internet connection.
Have a lovely day,
Nivedita Pa
Netgear Team- 77PALE77Aug 03, 2023ApprenticeHi NiveditaP3,
I suppose your last answer was for Etarsha and not for me.
I got my install successfully about two weeks ago, and anyway I could do nothing now, as I am far from home until the end of this monthđ - EtarshaAug 03, 2023AspirantHello Nivedita,
I'll give that a try, I did follow the steps you previously posted and when I selected the file from the browse, I encountered the "unspecified server error". Hopefully it was just a corrupted download, I will reply after I re-download and try again later today.
And 77Pale77,
Thank you for confirming you didn't do anything different. I did read the files attached and since I was installing from 6.10.8 it didn't look like any other upgrades were needed.- StephenBAug 03, 2023Guru - Experienced User
Etarsha wrote:
I did follow the steps you previously posted and when I selected the file from the browse, I encountered the "unspecified server error". Hopefully it was just a corrupted download, I will reply after I re-download and try again later today.If you get that again, try rebooting the NAS. Then see if 6.10.9 ends up installed anyway.
FWIW, it is installed on my RN102, so it should work fine with your RN104.
Hello NiveditaP3
I tried downloading the ReadyNASOS-6.10.9-arm from the link you provided and I am still having the "unrecognized server error". After a NAS reboot, I tried again the .zip, then the .img and even tried putting them in different locations (c://, d://, on the NAS storage itself) to make sure it wasn't a permissions issue. Still no luck.
I am using the RadyNAS 214, antivirus 02Aug2023 02:34:4 so at least that is getting updated. I have file search enabled, running firmware 6.10.8. Checking for updates results in "Your system does not need a firmware update". The firmware version 6.10.8 appears to be causing issues with my installed apps and now I cannot even upgrade to 6.10.9; any other suggestions?
