77PALE77
Jul 24, 2023Apprentice
RN104 Is manual install of 6.10.9 safe?
Hi everyone, my RN104 says its firmware 6.10.8 is up to date, even if I search for updates no update ion any kind s available; but I know there is a 6.10.9 release. Is it safe to upload it on the N...
NiveditaP3
Aug 03, 2023NETGEAR Expert
Hello 77PALE77
Could you please try downloading and installing the .img file again.
Please make sure your ReadyNAS is getting proper internet connection.
Have a lovely day,
Nivedita Pa
Netgear Team
Etarsha
Aug 03, 2023Aspirant
Hello Nivedita,
I'll give that a try, I did follow the steps you previously posted and when I selected the file from the browse, I encountered the "unspecified server error". Hopefully it was just a corrupted download, I will reply after I re-download and try again later today.
And 77Pale77,
Thank you for confirming you didn't do anything different. I did read the files attached and since I was installing from 6.10.8 it didn't look like any other upgrades were needed.
And 77Pale77,
- StephenBAug 03, 2023Guru - Experienced User
Etarsha wrote:
I did follow the steps you previously posted and when I selected the file from the browse, I encountered the "unspecified server error". Hopefully it was just a corrupted download, I will reply after I re-download and try again later today.If you get that again, try rebooting the NAS. Then see if 6.10.9 ends up installed anyway.
FWIW, it is installed on my RN102, so it should work fine with your RN104.
