AND268Y
Jul 30, 2014Aspirant
RN104 Keeps crashing/hanging
Hi I recently bought a RN104 to use as an iSCSI target for a small 2 node VMWare cluster hosting 5 vms. Each host has 2 separate gigabit nics with jumbo frames enabled to give dual path access to ...
mdgm-ntgr
Jul 30, 2014NETGEAR Employee Retired
Can you try the latest 6.1.9 RC?: http://www.readynas.com/forum/viewtopic.php?f=154&t=72282
In the 6.1.9 RC you should see a new option that allows you to disable sync writes for iSCSI. Can you see if that option helps you?
