AND268Y
Jul 30, 2014Aspirant
RN104 Keeps crashing/hanging
Hi I recently bought a RN104 to use as an iSCSI target for a small 2 node VMWare cluster hosting 5 vms. Each host has 2 separate gigabit nics with jumbo frames enabled to give dual path access to ...
mdgm-ntgr
Aug 01, 2014NETGEAR Employee Retired
A 2 node VMWare cluster hosting 5 VMs may sound small to you, but it's a lot for the 102 and probably too much.
You could see if disabling sync writes helps but the problem may reappear.
The status logs don't tell us much. It is the logs zip file that has the info that can help tell why a system crashed. See http://www.readynas.com/kb/faq/misc/how_do_i_send_all_logs
