AND268Y
Jul 30, 2014Aspirant
RN104 Keeps crashing/hanging
Hi I recently bought a RN104 to use as an iSCSI target for a small 2 node VMWare cluster hosting 5 vms. Each host has 2 separate gigabit nics with jumbo frames enabled to give dual path access to ...
AND268Y
Aug 02, 2014Aspirant
I wasn't aware that downloading the logs gave you the full system logs!
These have been downloaded and emailed as per the instructions. It may be down to performance in which case I may have to migrate some guests off the cluster or buy another NAS to spread the load. I have already upgraded to 6.1.9 rc8 and disabled sync write to see if this helps so will monitor for it happening again.
The UPS issue still exists. When trying to add it via the web interface as a snmp ups, this is the error that I am getting
Failed to communicate with UPS.<br />Error in during post proc
Code: 17003030001
Datetime: 08:16:31 08/02/2014
Code: 17003030001
