Kiptanoi_New
Aug 01, 2019Aspirant
RN104: Need some help, cant change http, https settings, and apps dont show up.
As you can see here https://imgur.com/Dh4j6rq It showing me that my http and htpps settings are disable? But when I click on http for example it look like this https://imgur.com/KmEPBa0 And I can...
Aug 01, 2019Guru - Experienced User
There is something here to fix, but it'd be useful to know why the NAS is resyncing. You shouldn't be rebooting it while it is resyncing.
You should download the log zip file. Then send a link (dropbox, google drive, etc) to the mods ( JohnCM_S or Marc_V ) and ask them to analyze them for you. Do that in a private message (PM) - clicking on the envelope icon in the upper right of the forum. Don't post the link publicly.
Also, if you don't have a backup of your files you should make one. Your data is at risk.
- Kiptanoi_NewAug 01, 2019Aspirant
Hi
The NAS is resync my new disks I put in yesterday.
So now when the resync is done I have made a backup job for my files to other disk at network.After that is complete, I am going to restore to factory default on nas, and then put in the three 4TB disk I want to use in X-Raid.
And see if that help me out.
If it does help I will recover my files to the X-Raid when Resync is completed on the three disks.
- StephenBAug 01, 2019Guru - Experienced User
It'd be more efficient to power down the NAS, install the final set of disks, and then use the boot menu to do a factory default.
That will also completely reinstall the OS, so your issue with HTTPs settings should be resolved.
Note that "available apps" can take some time to show up. You can alternatively download the apps from apps.readynas.com and install them manually. I also recommend checking out www.rnxtras.com - there is a small charge, but you'll get support in return.
Don't over-do it with apps - your RN104 has a relatively slow CPU and much less RAM than current models. And older apps can destabilize your system.
So, I dont need to backup my data on the disk?
I just can wait until tomorrow, and then put in my new disk, and make a factory default run on the NASand after that I have my data left on my disk?
If I dont need to do a backup of the data on the disk now then I be happy by that, and that save som time.
But I dont want to loose that data on that disk, But I did think if I do a factory default setup I would loose the data on the disk there is in now?
Yeah, I currently have 0 apps on the mashine, and only use 3 apps on it in the past: PHP, MySQL, and phpMyAdmin.
