Kiptanoi_New
Aug 01, 2019Aspirant
RN104: Need some help, cant change http, https settings, and apps dont show up.
As you can see here https://imgur.com/Dh4j6rq It showing me that my http and htpps settings are disable? But when I click on http for example it look like this https://imgur.com/KmEPBa0 And I can...
Kiptanoi_New
So, I dont need to backup my data on the disk?
I just can wait until tomorrow, and then put in my new disk, and make a factory default run on the NAS
and after that I have my data left on my disk?
If I dont need to do a backup of the data on the disk now then I be happy by that, and that save som time.
But I dont want to loose that data on that disk, But I did think if I do a factory default setup I would loose the data on the disk there is in now?
Yeah, I currently have 0 apps on the mashine, and only use 3 apps on it in the past: PHP, MySQL, and phpMyAdmin.
Aug 01, 2019Guru - Experienced User
Kiptanoi_New wrote:
But I did think if I do a factory default setup I would lose the data on the disk there is
Yes. So you do need a backup.
What I was meaning to say is that if you do a factory reset with one disk in place, and then add the others you will end up doing 3 resyncs - each one taking longer than the last one.
It's faster to do the reset with all disks in place, as then you do only one sync when the volume is created.
But either way you will ned to restore your data from backup after you do the reset.
- Kiptanoi_NewAug 01, 2019AspirantAh, yeah, I dont think the backup is done untill I got the new disk tomorrow anyway đ€Ł
But thanks for the answers and help so far :)- Kiptanoi_NewAug 02, 2019Aspirant
Finaly, after 24 hour of backing up 4TB data to other space in network...... I must say, the speed in this mashine is not the greatest....
15-30 Mb/s....... So that the downside about the NAS......
Anyway, I have done a factory reset, and my 3 disks are resyncing now, and they are emty, and I can now change the HTTP settings and the HTTPS settings again.....
But..... I cant install or view apps, available apps is loading for a sec, then it stops and nothing more happens.....
completly emty.....
And when I try to install them manually it fails, and say it cant be installed..... :(
How can I solve that? I do need MySQL and phpMyAdmin on the NAS- StephenBAug 02, 2019Guru - Experienced User
I suggest waiting for the resync to complete, and then add the apps.
I suggest avoiding the free versions, and purchasing them from https://rnxtras.com/readynas-os6-arm
