Kiptanoi_New
Aug 01, 2019Aspirant
RN104: Need some help, cant change http, https settings, and apps dont show up.
As you can see here https://imgur.com/Dh4j6rq It showing me that my http and htpps settings are disable? But when I click on http for example it look like this https://imgur.com/KmEPBa0 And I can...
Kiptanoi_New
Ah, yeah, I dont think the backup is done untill I got the new disk tomorrow anyway 🤣
But thanks for the answers and help so far :)
Kiptanoi_New
Aug 02, 2019Aspirant
Finaly, after 24 hour of backing up 4TB data to other space in network...... I must say, the speed in this mashine is not the greatest....
15-30 Mb/s....... So that the downside about the NAS......
Anyway, I have done a factory reset, and my 3 disks are resyncing now, and they are emty, and I can now change the HTTP settings and the HTTPS settings again.....
But..... I cant install or view apps, available apps is loading for a sec, then it stops and nothing more happens.....
completly emty.....
And when I try to install them manually it fails, and say it cant be installed..... :(
How can I solve that? I do need MySQL and phpMyAdmin on the NAS
- StephenBAug 02, 2019Guru - Experienced User
I suggest waiting for the resync to complete, and then add the apps.
I suggest avoiding the free versions, and purchasing them from https://rnxtras.com/readynas-os6-arm
- Kiptanoi_NewAug 03, 2019Aspirant
So I cant do anything with my NAS for 2-3 days while it syncing?
Not do any settings, changes, create maps, or install apps on it?avoiding the free? I have been using the free ones on the nas and have the nas running with it for 3 years now without any problem.
So what is the diffrent with that you are linking? - StephenBAug 03, 2019Guru - Experienced User
Not do any settings, changes, create maps, or install apps on it?You shouldn't reboot it in the middle of a sync - that is just asking for trouble. You can usually make changes (though performance is slow) - but obviously something isn't quite right with your install.
One possibility is to start over with just one drive in place, and do the full setup - verifying that eveything is working. Then hot-insert the remaining drives (one at a time) to build up the full volume. However, that will take much longer than letting the resync complete. So I'd probably wait for the resync - and if the http/https settings issue is still there, I'd then try an OS reinstall.
So what is the diffrent with that you are linking?Netgear has been upgrading the OS-6 linux kernel and associated libraries fairly regularly. That has created stability issues with several of the free apps - many of them aren't up to date, and the app provider is often longer around.
The ones on rnxtras.com are very inexpensive ( €4.98 for the pair). They are kept up to date, and you will get support if you run into issues. Note I'm not associated in any way with that site - I don't receive revenue or any other considerations from WhoCares_ (who runs it).
- Kiptanoi_NewAug 03, 2019AspirantThe last thing I did was a facory reset with my 3 disk in it, and can see on the display that it is resync now, so I am going to let it be that way and not going to log in or do anything with it until the resync is done....
Its about 22.50% done now, so about 30-35 hours or so it is complete :p - Kiptanoi_NewAug 04, 2019Aspirant
I will soon give up hope on NETGEAR.........
I started over with a old disk that whas inside before, did a fatcory reset....
And problem still there,,,,,
So I rolled back from firmware V6.10.1 to V6.10.0.....After that my nas did a automatic firmware update to V6.10.0 hotfix 2
And after that I could see and install apps from apps tab.....
So I installed mysql server and phpmyadmin....
imported my database and users.And now is a new problem, that Kodi cant connect to the databse.....
ERROR: Unable to open database: kodi18_music72 [2002](Can't connect to MySQL server on '192.168.1.78' (10060))
And all this **bleep** from changing disk in the nas.....
NETGEAR is a big joke and just crappy **bleep** right now.
