martyn20
Jul 03, 2014Aspirant
RN104 New Volume
Could not see this particular problem, forgive me if I have missed it and started another thread for nothing. I have a new RN104, I started it for the first time with a new 4TB disk and followed the ...
- Jul 03, 2014With RAID-1 the two disks are mirrored, so adding the second drive does not add capacity - it adds redundancy. If you hot-insert a third 4 TB drive the space will increase to 7.2 TiB, and the NAS will switch to RAID-5. You still have redundancy which protects against a single drive failure.
If you wanted jbod (no RAID) then you should start over with another factory reset (with only one drive installed), switch to FLEXRAID/JBOD, and hot-insert the second drive.
Adding a new disk to the RN104 is easy, I am puzzled by your comment on "not simple to add more disks".
norrispackard
Nov 30, 2016Tutor
Hi all. I had 3x3TB caviar red hdd into my rn104. Last week I hot install the 4th, wait it to rebuild but at the end not increase the capacity, it remain to 5.5 tbyte. I read about to reboot the system and I did also but remain to 5.5 instead of 9. Have you suggestions? Thanks a lot.
- StephenBNov 30, 2016Guru - Experienced User
Try downloading the logs, and look in mdstat.log and volume.log for the status of the newly added disk.
- norrispackardNov 30, 2016Tutor
hi, mmmm, seems to be not into the raid...
Number Major Minor RaidDevice State
0 8 18 0 active sync /dev/sdb2
1 8 34 1 active sync /dev/sdc2
2 8 50 2 active sync /dev/sdd2
3 8 2 3 active sync /dev/sda2
/dev/md/Server-0:
Version : 1.2
Creation Time : Wed Sep 9 06:57:33 2015
Raid Level : raid5
Array Size : 5850833664 (5579.79 GiB 5991.25 GB)
Used Dev Size : 2925416832 (2789.89 GiB 2995.63 GB)
Raid Devices : 3
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Wed Nov 30 18:49:36 2016
State : clean
Active Devices : 3
Working Devices : 4
Failed Devices : 0
Spare Devices : 1- StephenBNov 30, 2016Guru - Experienced User
You could try removing the new disk, unformatting it in a PC (the "quick zero" test in WDC's lifeguard program will do that), and then reinserting it into the ReadyNAS.
Netgear could probably solve it remotely too - perhaps wait a bit and see if someone offers to help.
