martyn20
Jul 03, 2014Aspirant
RN104 New Volume
Could not see this particular problem, forgive me if I have missed it and started another thread for nothing. I have a new RN104, I started it for the first time with a new 4TB disk and followed the ...
- Jul 03, 2014With RAID-1 the two disks are mirrored, so adding the second drive does not add capacity - it adds redundancy. If you hot-insert a third 4 TB drive the space will increase to 7.2 TiB, and the NAS will switch to RAID-5. You still have redundancy which protects against a single drive failure.
If you wanted jbod (no RAID) then you should start over with another factory reset (with only one drive installed), switch to FLEXRAID/JBOD, and hot-insert the second drive.
Adding a new disk to the RN104 is easy, I am puzzled by your comment on "not simple to add more disks".
Nov 30, 2016Guru - Experienced User
Try downloading the logs, and look in mdstat.log and volume.log for the status of the newly added disk.
norrispackard
Nov 30, 2016Tutor
hi, mmmm, seems to be not into the raid...
Number Major Minor RaidDevice State
0 8 18 0 active sync /dev/sdb2
1 8 34 1 active sync /dev/sdc2
2 8 50 2 active sync /dev/sdd2
3 8 2 3 active sync /dev/sda2
/dev/md/Server-0:
Version : 1.2
Creation Time : Wed Sep 9 06:57:33 2015
Raid Level : raid5
Array Size : 5850833664 (5579.79 GiB 5991.25 GB)
Used Dev Size : 2925416832 (2789.89 GiB 2995.63 GB)
Raid Devices : 3
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Wed Nov 30 18:49:36 2016
State : clean
Active Devices : 3
Working Devices : 4
Failed Devices : 0
Spare Devices : 1
- StephenBNov 30, 2016Guru - Experienced User
You could try removing the new disk, unformatting it in a PC (the "quick zero" test in WDC's lifeguard program will do that), and then reinserting it into the ReadyNAS.
Netgear could probably solve it remotely too - perhaps wait a bit and see if someone offers to help.
- norrispackardDec 07, 2016Tutor
Hi, following your instructions everithing run well. take 4 day for resincronizing and now i have all TB avaiable.
Thanks a Lot
- StephenBDec 08, 2016Guru - Experienced User
I'm glad you are up and running again.
