martyn20
Jul 03, 2014Aspirant
RN104 New Volume
Could not see this particular problem, forgive me if I have missed it and started another thread for nothing. I have a new RN104, I started it for the first time with a new 4TB disk and followed the ...
- Jul 03, 2014With RAID-1 the two disks are mirrored, so adding the second drive does not add capacity - it adds redundancy. If you hot-insert a third 4 TB drive the space will increase to 7.2 TiB, and the NAS will switch to RAID-5. You still have redundancy which protects against a single drive failure.
If you wanted jbod (no RAID) then you should start over with another factory reset (with only one drive installed), switch to FLEXRAID/JBOD, and hot-insert the second drive.
Adding a new disk to the RN104 is easy, I am puzzled by your comment on "not simple to add more disks".
Jul 03, 2014Guru - Experienced User
Well, to be clear, it did change the volume. Capacity didn't expand, but that was not related to the operating system at all. If you want to understand it better, you need to do some research on RAID.
martyn20 wrote: Thanks I will do as you say. I thought just adding new disks would change the volume and expand the capacity instantly, I did not think it out, with some of the operating system using the disks
